What Are The Machines That Vacuum Out Attic Insulation Called? - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-02-2013, 08:26 PM   #16
Registered User
Rewards Points: 5,498
I set one up for a remodel contractor I worked for about 10 years ago, he needed it often; http://www.harborfreight.com/1-hp-mi...tor-94029.html hooked it up with the cloth bag above a standard plastic garbage bag (contractor size) with quick connects/pipe stand so person below could compact the f.g. occasionally. 100' of 4" flex hose and adapter/8' extension pipe nozzle (local contractor supply store). Then Sears came out with the portable leaf vacuum/blower...
Gary
Old 06-02-2013, 08:32 PM   #17
Bill Kearney
Rewards Points: 1,174
I've got one of those blowers and I wouldn't say it's got enough power to pull from too long of a hose. But then I was using it to handle woodworking debris not fiberglass.
wkearney99 is offline   Reply With Quote
Attic Insulation & Sealing planning fstr Insulation 7 11-19-2012 10:54 AM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Damp Insulation in Attic wiz561 Building & Construction 6 12-23-2010 11:16 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
