What Kind Of Insulation To Use For My Basement? - Insulation - DIY Chatroom Home Improvement Forum
Old 06-25-2013, 10:35 AM   #1
Rewards Points: 37
Question
What kind of insulation to use for my basement?
Our newly rebuilt basement is taking shape and soon we will start closing it with sheetrock, meaning that we have to decide on insulation.
The house is all-brick from 1930's here in Brooklyn, NY. It has all new sewers and I have never seen any water in the basement during the few years we have owned the house. The basement goes about 5 feet underground (measured from the inside) The only heating / air conditioning in the basement will be provided by a 9,000 BTU LG HVAC system airhead. I plan to install a portable humidifier that will be periodically on. Summers here are very humid and winters are dry.
A few suggestions were made to me about which type of insulation to use, so I would like to hear some feedback on each method:
1) Using the spray-on foam. But which one? I hear that if it's not done properly, it could create a bad moisture situation
2) Using the standard R-11 that is sold in Home Depot / Lowes
3) Using Roxul's product Comfortbatt (R15/16 or R23): http://www.roxul.com/products/reside...ul+comfortbatt
Also: Will I need a vapor barrier in general?
Any and all opinions are much appreciated!
mystiky is offline   Reply With Quote
Old 06-29-2013, 09:30 AM   #2
roofingquotes's Avatar
Here's a good post that might help you on choosing the right type of insulation. Check it here: http://energy.gov/energysaver/articles/types-insulation
roofingquotes is offline   Reply With Quote
Old 06-29-2013, 11:34 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,972
Rigid foam is cheapest in terms of getting foam performance.
If the walls are already up and you want it to be easier, just use SPF (Spray Polyurethane Foam).
http://www.buildingscience.com/docum...commendations/
http://www.buildingscience.com/docum...doctypes/diges
Wet insulation in bathroom in basement goal80 Building & Construction 0 04-14-2013 10:21 PM
Basement wall insulation / remodel question Chokingdogs Insulation 2 03-14-2013 01:26 AM
Basement insulation on pre-built walls davinciwanab Insulation 5 02-28-2013 08:10 PM
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 05:42 PM
basement insulation help dp683 Insulation 2 11-14-2011 11:20 AM
