What Do I Look For ? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-17-2013, 10:43 AM   #1
Rewards Points: 222
what do i look for ?
one of these days, i am going to go up in my attic to do an inspection. i have never been up there when it is cold out. what issues should i be looking for ?
Fix'n it is offline   Reply With Quote
Old 02-17-2013, 10:55 AM   #2
Rewards Points: 13,296
Dripping water, being able to see day light around any roof penatrations, fungus or mold, cracked rafters.
It should be almost as cold in that attic as the outside. If it's warm your loosing heat through the ceiling from not being air sealed, not enough venting, or not enough insulation.
http://www.energystar.gov/index.cfm?...sulation_table
Old 02-17-2013, 11:35 AM   #3
Rewards Points: 222
thanx joe. thats about what i thought. i am also going to look at my brick chimney, whats left of it.
Old 02-25-2013, 01:33 AM   #4
Rewards Points: 1,092
black areas in insulation will indicate air leakage around penetrations. take some spray foam and/or caulk up w/ you, if it's warm enough to apply it. otherwise, a notebook and pencil.
