What To Do About Cold Walls In Winter - Insulation - DIY Chatroom Home Improvement Forum
Old 06-23-2014, 11:17 AM   #1
What to do about cold walls in winter
Home was built in 1994. It is a 2 story contemporary Cape Cod. I was suggested by contractor to have blown in insulation in walls. Is this good? What about present insulation in walls? What other suggestions would help? Thanks
TRANSAM is offline   Reply With Quote
Old 06-23-2014, 11:26 AM   #2
Rob
Robpo's Avatar
Rewards Points: 826
That is when there isn't insulation in there.
Robpo is offline   Reply With Quote
Old 06-23-2014, 11:54 AM   #3
Rewards Points: 144
Get another contractor.If the house was built in 1994 the walls are insulated with batt most likely.You can't blow in insulation on top of batt.
Check all of your windows and doors for air intrusion.
mako1 is offline   Reply With Quote
Old 06-24-2014, 03:26 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
If you have batts, you won't effectively get more insulation in there and you need to tell us more about the construction to get the correct recommendations.
Old 07-02-2014, 01:21 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
We dense pack walls with batting regularly. You can find videos online showing how the cellulose will fill the cavity and compress the fg. The question is whether or not it is worth it for ROI based on what type of batting is in there. On a home built in 94, you probably have the correct batting in there (r13 for 4" framing or r19 for 6") in which case it would probably not be a wise investment. If you can get someone in with a blower door and thermal cam to take a look you'll be able to see if there are uninsulated cavities, etc.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Windows on Wash (07-02-2014)
Hot water from cold pipes, plumbers are stumped seabeast Plumbing 75 03-31-2015 09:52 PM
Cold Air Return RichTibo HVAC 1 10-06-2013 09:16 AM
Cold in winter and hot in summer giannishadj General DIY Discussions 24 11-27-2012 11:14 AM
Trickle of Cold Water Pioneer Bathtub Faucet egawrons Plumbing 0 10-25-2012 11:24 AM
Freezing Cold Walls benchmarkman Building & Construction 11 01-11-2010 03:05 PM
