Wet Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 07:36 PM   #1
Wet Walls
Hello everyone,
I'm renovating a bathroom, which is currently down to the studs. I just pulled back some of the batts in the walls to find that some sections were moist, other areas were wet. I suspect it might be caused by a failure in the vapour barrier as I do not see any signs of severe leaking.
I can see that I'm going to have to remove the insulation from the walls, allow it to dry, and then re-insulate - my question is, I imagine this might be going on all throughout my house. Is there a permissible amount of condensation that can occur without causing severe damage? I really don't want to have to tear my entire house apart to re-apply a vapour barrier.
I live in Edmonton, Alberta, where our winters are long and cold. That said, even if I do remove the insulation, are the walls even going to dry, with it still being below 0?
mforeman1 is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 09:20 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 04:12 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
