-   Insulation (http://www.diychatroom.com/f103/)
-   -   Wet Walls (http://www.diychatroom.com/f103/wet-walls-98530/)
mforeman1 03-15-2011 07:36 PM
Wet Walls
Hello everyone,
I'm renovating a bathroom, which is currently down to the studs. I just pulled back some of the batts in the walls to find that some sections were moist, other areas were wet. I suspect it might be caused by a failure in the vapour barrier as I do not see any signs of severe leaking.
I can see that I'm going to have to remove the insulation from the walls, allow it to dry, and then re-insulate - my question is, I imagine this might be going on all throughout my house. Is there a permissible amount of condensation that can occur without causing severe damage? I really don't want to have to tear my entire house apart to re-apply a vapour barrier.
I live in Edmonton, Alberta, where our winters are long and cold. That said, even if I do remove the insulation, are the walls even going to dry, with it still being below 0?
