Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 05-06-2011, 10:20 PM   #1
Question
Wet uninstalled R-30 fiberglass rolls
Is there any way to dry and uncompress rolls of R-30 unfaced fiberglass that got wet?
I had some rolls covered on a tarp outdoors when heavy rains hit. Water collected on the tarp and soaked into the bottom of 5 rolls through some rips in the plastic.
I've removed the plastic from the wet rolls to let any soaked water drain. Unrolling one of them, I found that about 75% of the width is dry and expands to its normal thickness. Is there any way to dry out the portions that took on water, or are all these rolls a total loss?
Last edited by SteveL0530; 05-07-2011 at 08:32 AM. Reason: Change post icon; moved question to beginning
SteveL0530 is offline   Reply With Quote
Old 05-09-2011, 05:15 PM   #2
Moderator
You could dry it out. If any dirt (organic) got into the f.g. and it warms up and is still wet after install, it could mold; http://www.inspectapedia.com/sickhou...rglassMold.htm
Gary
Clothes taking longer to dry?
Tags
fiberglass insulation, uninstalled, wet
The "biggest loser" in fiberglass insulation.... Gary in WA How To Guides 1 01-18-2011 07:37 AM
cellulose over blown in fiberglass? deerhunter Building & Construction 1 10-29-2010 11:16 PM
Exposed fiberglass insulation in partially-finished basement skysurf Building & Construction 1 04-11-2009 10:40 AM
Diference between Fiberglass and Hard Foam shumakerscott Roofing 3 09-06-2008 01:16 PM
Is fiberglass insulation safe for us with dishwasher? jen78fl General Discussion 10 01-31-2008 06:51 PM
