Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 11-12-2012, 05:10 PM   #1
wet insulation
Due to the storm surge, the insulation in my crawl space got wet . The is no water now and the crawl is well ventilated. Do I need to replace the insulation(fiberglass) or can I just let it dry on its own? Thanks
birdie2 is offline   Reply With Quote
Old 11-12-2012, 05:18 PM   #2
wet insulation
It's trash now and if left in place you can be 100% mold will be setting in because the wood can not dry out.
Old 11-12-2012, 05:59 PM   #3
concretemasonry's Avatar
wet insulation
Get it out and toss it.
Insulation does not dry out just from warmer temperatures and it need active air circulation (low humidity) all around it on all sides and agitation.
Many people sadly discovered this after Katrina when they thought they had dried it out and then refinished the space, just to be faced by a disaster.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Windows on Wash (11-13-2012)
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 07:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 06:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 12:16 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Rafter Vents and Insulation nofx1981 Roofing 15 03-10-2010 09:14 PM
