Wet Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 11-05-2012, 09:04 PM   #1
wet insulation
I was having roof put on storm came up and rained the insulation got wet does it have to pe replaced ?
mbieloski is offline   Reply With Quote
Old 11-05-2012, 09:34 PM   #2
Rewards Points: 222
what kind of insulation is it ? probably fiberglass. i would just leave it, check it to see well it is drying. and watch for mold.
Fix'n it is offline   Reply With Quote
Old 11-06-2012, 09:28 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,994
What type of insulation?
Should dry out under normal conditions as Fix said. If you are worried, rip it out and replace.
Insulation is cheap so err on the side of caution if you are concerned.
Wear proper protective gear.
Old 11-06-2012, 09:47 PM   #4
Rewards Points: 222
Originally Posted by Windows on Wash View Post
Insulation is cheap
yeah, well, that depends on how it is looked at . i just put $300 in my attic, and i need $300 more. and that is only 2/3 of my attic.
BUT, it is an investment that really does pay for itself MANY times over.
Old 11-07-2012, 12:53 AM   #5
I was more so referring to the small area that he/she would likely have to replace.
In terms of payback though...it still is cheap.
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 07:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 06:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 12:16 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
