-   Insulation (http://www.diychatroom.com/f103/)
-   -   wet insulation (http://www.diychatroom.com/f103/wet-insulation-162329/)
mbieloski 11-05-2012 09:04 PM
wet insulation
I was having roof put on storm came up and rained the insulation got wet does it have to pe replaced ?
Fix'n it 11-05-2012 09:34 PM
what kind of insulation is it ? probably fiberglass. i would just leave it, check it to see well it is drying. and watch for mold.
Windows on Wash 11-06-2012 09:28 PM
What type of insulation?
Should dry out under normal conditions as Fix said. If you are worried, rip it out and replace.
Insulation is cheap so err on the side of caution if you are concerned.
Wear proper protective gear.
Fix'n it 11-06-2012 09:47 PM
Originally Posted by Windows on Wash (Post 1046303)
Insulation is cheap
yeah, well, that depends on how it is looked at . i just put $300 in my attic, and i need $300 more. and that is only 2/3 of my attic.
BUT, it is an investment that really does pay for itself MANY times over.
Windows on Wash 11-07-2012 12:53 AM
I was more so referring to the small area that he/she would likely have to replace.
In terms of payback though...it still is cheap.
