Wet Cellulose Insulation.. Good Or Bad, Why? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-08-2012, 03:27 PM   #1
wet cellulose insulation.. Good or bad, why?
Hello, I'm deciding on insulation. I don't want fiberglass, spray foam is out of my price range.. Every time I research Wet Cellulose Insulation I find people arguing about it. Some say its great, some say its bad, some say it causes mold, others say that's because it wasn't allowed to dry properly. Anyone have personal experience with the product or know someone who does? If so how do you/they feel about it? If you do feel it's a bad choice, what would you recommend? My house is stucco on the exterior (actually gunite) and I live in Tulsa, if it helps. Thanks to all who reply
Travis89 is offline   Reply With Quote
Old 02-08-2012, 04:21 PM   #2
Cool
Cellulose Wall Spray
Other than possibly Doug fir studs you will find varied opinions about just about every building product on the market. The fact is that there is no such thing as a perfect building material, but if materials--including insulation--are specified correctly and used properly they will perform as they should. Cellulose insulation as we know it today has been around since the 1920s, and cellulose wall cavity spray (that's the correct term, not "wet cellulose") has been on the market since the 1970s. Does anyone seriously think the product would have a 30+ year history, let alone be steadily growing in market share, if it were "bad," or caused mold, or did any of the other bad things you hear about on the Internet? There are no endemic problems associated with any of the insulation mateials in common use today, but you can certainly find isolated horror stories stemming from improper application of cellulose, fiber glass, foam plastic, or any other insulation.
If cellulose wall cavity spray is installed correctly it will perform as it should and provide excellent energy saving service for the life of the building. If it isn't used correctly it may not work as it should. Of course, you can say the same thing about concrete, paint, siding, windows, or anything else you can put in a home.
dleaoh is offline   Reply With Quote
The Following User Says Thank You to dleaoh For This Useful Post:
Travis89 (02-14-2012)
Old 02-09-2012, 10:56 PM   #3
Rewards Points: 1,092
This was discussed a bit on the greenbuildingadvisor.com forum, if I recall, and it seems that the problems arise because people don't let it dry out properly, and esp if they use a poly vapor barrier. Duh... it IS wet, right? It takes xx days at yy % relative humidity for it to dry. Once dry, it is fine. I would not hesitate to use it, but I would also consider doing something to kill the thermal bridge the studs will make to the cold. The cellulose won't stop that. Can you put rigid foam on the outside as well? BTW: Research rain screens and stucco. I've read a bit about that stuff, and it rings of "potential water" for some reason.
The Following 2 Users Say Thank You to jklingel For This Useful Post:
Travis89 (02-14-2012), Windows on Wash (02-12-2012)
Old 02-14-2012, 09:11 PM   #4
Thanks to both of you for your replies. I think I've decided to go ahead and use it. I found a friend of a friend who says they can do for me for roughly 65 cents a sq foot.. That sounds pretty good to me. I'll absolutely allow it to dry properly and post up some pics. Thanks again.
Tags
cellulose , insulation , wet
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
I want more storage in the attic, have loose insulation, is it good? Flooring over? kaitala Insulation 7 11-04-2011 05:11 PM
Insulation: foam or cellulose? wombosi Insulation 1 07-06-2011 08:20 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
