Wet Cellulose ? - Insulation - DIY Chatroom Home Improvement Forum
Old 10-21-2012, 08:32 AM   #1
Rewards Points: 236
wet cellulose ?
what happens to cellulose when, and after, it gets wet ?
no, mine didn't get wet. but i bought some home when it was lightly raining, open pickup truck. and it got me to thinking.
Fix'n it is offline   Reply With Quote
Old 10-21-2012, 08:58 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,274
It dries out pretty quickly.
If it gets matted down, just crumble it back up.
Old 10-21-2012, 11:59 AM   #3
Wet Cellulose Insulation?
Cellulose wall cavity spray is installed at a moisture level of 30% to 40% as standard practice. 20-25 years ago this material was often installed at 60% moisture. Today that would not be regarded as good practice, because it often led to excessive moisture in sheathing, framing, and drywall and it made long drying times necessary. It didn't, however, have any negative effect on the insulation itself.
dleaoh is offline   Reply With Quote
Old 10-21-2012, 07:20 PM   #4
Rewards Points: 236
interesting, good to know.
i blew mine in today. boy, is this stuff fluffy. i feel like i don't have enough. about 10". i should have bought more bags.
Old 10-22-2012, 01:10 AM   #5
Enough cellulose?
If you followed the coverage chart, ie installed the number of bags in the bag count column, you have the R-value you specified. 10 inches at installed density is probably going to be around R-30 or a bit more at settled density depending on the brand. If you kept the technical specs for the product you installed you can always check the R-value by measuring depth and multiplying by the R-factor. Cellulose R-factor is not nearly as density dependent as fiber glass so fluffing isn't an issue.
Insulation - Cellulose vs. Icynene meth Building & Construction 25 12-17-2014 10:04 PM
Cellulose over Icynene?? adambook Insulation 3 01-20-2012 10:22 PM
Looking for feedback on cellulose insulation in an attic me040096 Insulation 2 01-06-2012 08:41 AM
Attic Insulation: Should I use fiberglass or cellulose? strategery Insulation 20 11-14-2011 11:10 AM
Another cellulose question Arky217 Building & Construction 1 10-29-2011 07:51 PM
