Is This The Way To Insulate A Rim Joist? - Insulation - DIY Chatroom Home Improvement Forum
Old 10-28-2013, 08:36 PM   #1
Is this the way to insulate a rim joist?
I recently had my crawlspace encapsulated and noticed there was still cold air getting in to the living space directly above our crawlspace. I went down to see if I could find the source of cold air and found this. I'm sorry for the small fonts in these pics put the yellow arrow is pointing to exposed rim joists. They did what I thought was a superb job until I found cold air (not much) leaking in through these areas. I don't think the fiberglass insulation was the way to go with this. I welcome any and all expert opinions on this please. I'm wanting to call these folks back but need to know if this is the correct acceptable method of encapsulating.
Is this the way to insulate a rim joist?-untitled.jpg   Is this the way to insulate a rim joist?-untitled2.jpg
teeb57 is offline   Reply With Quote
Old 10-28-2013, 08:38 PM   #2
Rewards Points: 13,960
Sure not the way I would have done it.
I would have used 2" foam and sealed any gaps with spray foam.
Dave Sal (11-04-2013)
Old 10-29-2013, 06:03 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,220
Based on the lack of access and difficulty navigating that area, a froth pak (Spray Foam) is going to be your best application here.
Old 10-29-2013, 06:16 AM   #4
Rewards Points: 2,516
Hard to see from your pictures but does not look good. Here are some before and after pictures from my job. The before are with all batt insulation and the after is with the spray foam. Majority of my rim joists were about 6" deep and 9" in height
Is this the way to insulate a rim joist?-100_4949.jpg   Is this the way to insulate a rim joist?-100_9672.jpg   Is this the way to insulate a rim joist?-10-high.jpg
hammerlane is offline   Reply With Quote
Old 10-29-2013, 12:06 PM   #5
From the looks of your pics, that looks like a very good job. I read some where that we need to be careful about using spay foam on rim joists however. I can't remember exactly but it seems I read that if the joist are below grade level spray foam shouldn't be used.
Thanks for the photos
Old 10-29-2013, 12:18 PM   #6
Dont know why that would be the case. In any event mine are well above grade
Old 10-29-2013, 01:32 PM   #7
Just not true!
Old 10-29-2013, 01:47 PM   #8
Originally Posted by joecaption View Post
Just not true!
I've looked for the article but now I can't find it. I think maybe I'm confusing it with the polyurethane foam.
Old 10-29-2013, 11:56 PM   #9
Registered User
Rewards Points: 526
Pages 6, 11; http://www.google.com/url?sa=t&rct=j...,d.cGE&cad=rja
http://www.buildingscience.com/docum...l_seal_rev.pdf
Gary
Old 10-30-2013, 09:11 AM   #10
Thanks for that Gary,
I see that foam is ok I guess so long as it's not open cell.
The Following User Says Thank You to teeb57 For This Useful Post:
Gary in WA (10-30-2013)
Sistering to correct warped joist... fprawlings4 Building & Construction 2 03-12-2013 08:04 PM
Level sagging floor joist EddieT06 Flooring 1 10-08-2012 05:27 PM
Insulate rim joist & basement walls- if exterior walls have no insulation? cbrc5eric Insulation 5 02-01-2012 07:47 AM
Floor Joist Notch trophywalleye Building & Construction 1 02-03-2011 03:49 PM
how to insulate rim joist with drop cieling BlueBSH Building & Construction 4 01-03-2010 07:45 PM
