Wall Vent Range Hood - Insulation - DIY Chatroom Home Improvement Forum
Old 03-06-2012, 06:56 PM   #1
Wall vent range hood
I want to install my range hood and vent it out the back through our wall with brick siding.
After I cut the hole through the wall, i plan on using expanding foam to fill in the gap between the cut out and the vent.
What if I encounter a vapour barrier that I have to cut through? How can I make sure that barrier stays seal after I cut through it?
It's a 35 year home and I don't know what to expect.
kingofmycastle is offline   Reply With Quote
Old 03-06-2012, 07:40 PM   #2
Rewards Points: 12,830
There most likly to be brick, a space, tar paper then plywood, insulation, then drywall or plaster.
There's 0 way to reseal the vaper barrier. It's not all that hard to get a really close cut so the all your going to need is silicone behind the flange on the vent cover outside.
Old 03-06-2012, 07:53 PM   #3
Should I even bother with the expanding foam to seal around vent and brick?
Old 03-06-2012, 08:25 PM   #4
If it's cut right there's not going to be any room for it and if it did expand it may close up the adapter.
range hood vent vinman Roofing/Siding 6 05-07-2012 02:23 PM
Range Hood Ducting go Down? jerryk1234 Kitchen & Bath Remodeling 15 09-22-2011 11:10 PM
external wall mount blower for range hood vjb Plumbing 2 12-28-2010 07:39 AM
How to remove/replace range hood roof vent? TipsyMcStagger Roofing/Siding 2 12-08-2010 10:10 AM
Installing range hood - wall vent DIYGST HVAC 3 01-04-2009 08:45 AM
