#1 |
Wall Top Plate Insulation
I searched the forums and can't seem to find the answer I'm looking for so here it goes. I am adding insulation to my attic and I currently have R-30 fiberglass batts in between the ceiling joists. I want to add R-30 fiberglass on top of that and run it perpendicular to the joists. The area I am having trouble with is how to add more insulation to the top of the wall plate where it meets the eaves of the house. I don't want to compress the new R-30, and I do have rafter vents installed. Could I just fill some bags with insulation and stuff it in there? Is there any value added? Hopefully the attached picture helps. The blue circle is what I am trying to figure out how to insulate.
#2 |
Wall Top Plate Insulation |
| The Following User Says Thank You to joecaption For This Useful Post: | chronojosh (11-10-2012) |
#3 |
Moderator
In the above link Joe gave, if you down-load the rest, they used f.g. in garbage bags at open studs and under knee-walls, which is fine. Yet where it should also stop incoming air movement at the exterior wall line, they say just use an air-permeable f.g. batt, without the bag! F.g. should not touch the roof sheathing (conduction) at the baffle sides yet something should protect it at that soffit end from wind-washing (degrading the R-value). Night-sky radiation will wet the insulation in contact with the sheathing; http://www.buildingscience.com/docum...bout-diffusion
Best is to use homemade baffles of foamboard (stopping all air movement to your f.g.) pp.72; and add rigid f.b. stacked at the exterior wall line- pp.71 (Option 3); http://www.buildingscience.com/docum...n-roof-venting Another opinion on f.b. over wall at the slope junction; http://bct.eco.umass.edu/publication...o-save-energy/ Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| The Following User Says Thank You to Gary in WA For This Useful Post: | chronojosh (11-10-2012) |
#4 |
Exterior Construction
Just spray it with the same stuff you are seal the top plates with.
+1 to Joe and GBRs suggestions too.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to Windows on Wash For This Useful Post: | chronojosh (11-10-2012) |
| Display Modes | |
| Where to apply vapor barrier(s) for wall insulation | patented | Insulation | 6 | 10-30-2012 12:17 AM |
| Jacking Exterior Wall / Replacing Sill Plate | Pittsville | Building & Construction | 2 | 06-16-2012 10:11 AM |
| Framing basement exterior walls | gheffron | Building & Construction | 7 | 06-08-2012 02:00 AM |
| Bottom Plate for Non-Load Bearing Wall | cobrakai | Carpentry | 2 | 02-08-2011 12:56 PM |
| 2x4 Exterior Wall Insulation | stubits | Building & Construction | 4 | 03-19-2009 08:03 AM |
