Wall Temperatures - Insulation - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 01:08 AM   #1
Wall temperatures
Hello,
I woke up this morning just as the sun came up and I thought to measure the temperature of my walls. My ceiling was 14 degrees Celsius, my outer walls were 15 degrees Celsius and my inner walls were 16 degrees Celsius. The outside temperature was around 9 degrees Celsius if not less.
Do these temperatures show that I need insulation? I know it will make a difference but will it make a noticeable difference if I insulate the roof?
Have in mind that it is an apartment, I own it but obviously I cannot go around on the roof and do whatever I want since it is a communal area. If I will do something I will have to do it inside the house or get permission to do it on the roof. No attic no nothing, its my ceiling and on the other side of the ceiling is the roof.
giannishadj is offline   Reply With Quote
Old 11-28-2012, 07:37 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
Pictures of the interior and exterior will help quantify what will be required and what the expense of such and undertaking would be.
Old 11-28-2012, 07:40 PM   #3
Rewards Points: 2,638
Do you mean the outdoor face of your wall is 15 degrees, and the indoor face of that wall is at 16 ?
What is the indoor air temperature?
SPS-1 is offline   Reply With Quote
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 07:49 PM
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 06:17 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
