#1 |
Wall insulation
Does anyone have experience with drilling holes in interior walls with a drill bit that cuts a circle instead of a hole ? The idea is to get a clean plug that can be glued spackled back in place without as much damage to the texture as a standard bit hole that is large enough to blow in retrofit insulation.
Are there any reasons to do retrofit wall insulation through holes in the outside? It would seem to be an un-necessary compromise of the moisture barrier. Thanks ! |
#2 |
Moderator
Wall insulation
You could drill/patch inside or outside, the correct powerful enough blower would be the main problem. The box store blower is fine for attic, not walls. I presume you mean cellulose, not f.g. http://www.karg.com/pdf/Insulaton_de...and_Biddle.pdf
http://www.affordablecomfort.org/ima...ck_Handout.pdf Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| The Following User Says Thank You to Gary in WA For This Useful Post: | DavidNielsen (06-07-2011) |
| Display Modes | |
| Exterior Wall Insulation | Dutchman80 | Building & Construction | 1 | 08-06-2010 10:28 PM |
| attic insulation / knee wall | oscarMadison | Building & Construction | 2 | 01-19-2010 09:37 PM |
| Marrying a sloping stone wall to a cinder block wall. | mrdol | Landscaping & Lawn Care | 1 | 11-09-2007 05:08 PM |
| Exterior wall insulation | ffgus | Remodeling | 4 | 11-06-2007 05:23 PM |
