Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 11-30-2011, 09:55 AM   #1
Walk-Out Basement Wall
I have received a lot of help here on my basement project. But I have read many articles and discussion on how to insulate my walk-out basement and i am stuck
We have the entire back side of our basement wall (2x6 stud/sheathing)that we are trying to figure out the best way to insulate.
The other walls in the basement are concrete 8ft high with 2x4 studing inch away and a 2x6 stud wall to the garage which is already insulated with kraft faced insulation R19.
I was wondering if you could use the Extruded Polystyrene Foam boards on the outside wood basement walk out wall not concrete? Or should i use the unfaced batts or faced batts and dyrwall over?
Thanks for the help
ddave23 is offline   Reply With Quote
Old 11-30-2011, 10:58 AM   #2
Exterior Construction
Windows on Wash's Avatar
I was thinking through the exact same question in my basement today while getting some tools put together.
The foam is best suited to be against the concrete wall. If you have a 1" gap, you should be able to slide it between the studs and get it against the wall.
Applying it to the interior stud wall will create a complete vapor barrier if it is the polyethylene skinned type of XPS.
The vapor barrier control of that board is most effectively placed directly against the interior concrete wall.
I may be misunderstanding your question so I apologize in advance if I did.
Old 11-30-2011, 03:07 PM   #3
I used ROXUL on the wood,above grade side of my walkout basement.
Bonus is that ROXUL in 2X6 studs gives you R-23 vs R-19,and it is moisture and mold resistant.
spring3100 is offline   Reply With Quote
Old 12-19-2011, 09:59 AM   #4
question ; What did you guys do with the little concrete wall under the sliding door. Not sure what you call it but on my wlakout basement I have an 1-2 inches of concrete at thebase of my mostly insulated wall.
Do you use a small piece of rigid foam all along ther bottom?
fenders is offline   Reply With Quote
Old 12-20-2011, 09:01 AM   #5
Is the wall being framed out with 2x4/6's?
If not, I would leave it alone. People will invariably step on the foam and break it off it you don't have it protected with some sort of extension jamb.
It is not that big a thermal short circuit in the greater picture and there is alot more the basement that can take improvement first I would bet.
Old 12-23-2011, 09:52 AM   #6
I have never used ROXUL before...do I need a vapor barrier on top of the ROXUL?
Old 12-24-2011, 01:03 PM   #7
Yes, on the inside:
http://www.roxul.com/residential/how+to+install+roxul
The insulation is porous and would allow warm, moisture-laden air from the interior to hit cold sheathing, creating a condensation problem.
benjamincall is offline   Reply With Quote
Old 12-24-2011, 03:28 PM   #8
Moderator
Foamboard outside is good to raise the dew point of the wall cavity to prevent condensation; http://www.buildingscience.com/docum...apor-retarders
http://www.greenbuildingadvisor.com/...foam-sheathing This way eliminates the plastic vapor barrier inside, reducing the Class required, if under the IRC; http://publicecodes.citation.com/ico...001_par004.htm
http://publicecodes.citation.com/ico...001_par005.htm
It also prevents thermal bridging of the wall studs/plates.
What will be the siding material?
Gary
Clothes taking longer to dry?
Need to Install Hand Rail on Basement Stairs, but on Concrete Wall Firehawk734 Building & Construction 40 01-18-2012 09:33 AM
Basement floor leaking after wall repair unfortunateluck Building & Construction 6 02-15-2011 07:05 PM
vapor barrier on basement pony wall hobbs in vanvouver Building & Construction 3 02-13-2011 09:07 AM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General Discussion 5 02-02-2011 09:39 AM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 11:24 PM
