Vinyl Siding - Insulation - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 08:14 AM   #1
vinyl siding
when installing vinyl siding over old clapboard should foam board insulation be installed first?
vicwestim is offline   Reply With Quote
Old 06-01-2012, 03:04 PM   #2
AGWhitehouse's Avatar
Read manufacturer's recommendations
I say that because it can vary depedent on the exact product. Some do, some don't...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 06-01-2012, 05:12 PM   #3
Rewards Points: 13,456
Any brand I've ever used says to use fan fold foam. It's helps level out the surface.
Old 06-01-2012, 05:59 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,142
Use the board manufacturer's recommendations.
Old 06-02-2012, 02:57 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+2. Hollow core vinyl will either get fanfold or thicker rigid foam board, while an insulated back siding generally gets a house wrap. You definitely do not want to do anything that contradicts the manufacturer instructions, however they are also generally the "bare minimum".
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
