Vaulted Celing - Replace Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 12-02-2012, 11:09 AM   #1
Question
Vaulted celing - replace insulation
I have read the pros and cons on vaulted ceilings. we have had vents in the roof cause of the moisture seeped into the laundry room. I really need to replace the insulation but there is no room to do it. What do you suggest and what is up to code and will keep the house warm??
Jlelbert is offline   Reply With Quote
Old 12-02-2012, 12:18 PM   #2
Rewards Points: 1,092
I'm not clear on exactly what is going on. Where'd the water come from, exactly? What type of insulation do you have, and why are you replacing it? How much room do you have for insulation? How are you going to access the insulation; from inside? Greenbuildingadvisor.com has a blog on "how to insulate a cathedral ceiling" ( or similar title) that my be of interest. Spray foam may be an option for you.
Insulation maitenance after remodel k2000lbs Insulation 10 02-19-2012 10:04 AM
Insulating & Ventilating Vaulted Ceiling fgaldes Building & Construction 2 08-12-2010 02:51 PM
blown in attic insulation, replace or add to Yoyizit HVAC 17 11-10-2008 08:25 AM
Old home insulation woes nowwhatnapster Building & Construction 15 11-02-2008 11:59 PM
Vaulted Ceiling Insulation Problem casey_wa Roofing/Siding 13 05-08-2006 09:55 AM
