01-17-2013, 03:14 PM
#1
Vaulted Ceilings
Okay, quick question, I installed R-19 fiberglass insulation in my vaulted ceiling, in 2 x 8 rafters. Someone, plumber on site, mentioned whether or not I was going to use the foam 'egg crate' things for ventilation.
It got me thinking but R-19 is less than 6" and the rafter is 7 1/2", I believe I should have plenty of an air gap between the ridge vent and the eves.
Please let me know your thoughts.
01-17-2013, 04:04 PM
#2
Vaulted Ceilings
i am required to have a 1" air space between the insulation and the bottom side of roof sheathing here......
01-17-2013, 04:14 PM
#3
Vaulted Ceilings
I don't know what we're required to have, SE PA, but I have at least an inch so I think I'm safe. I will find out soon enough.
01-18-2013, 12:12 AM
#5
Moderator
Vaulted Ceilings
BSC recommends 2" gap as 1" (minimum code) is not sufficient, baffles all the way; http://www.buildingscience.com/docum...n-roof-venting
Gary
Clothes taking longer to dry?
01-18-2013, 08:47 AM
#6
Vaulted Ceilings
Thanks for the replies. There's about a 2" gap so I think I'm set. I guess if I'm wrong the BI will tell me when they come out.
01-18-2013, 08:41 PM
#8
Residential Designer
Vaulted Ceilings
Are your ceilings vented?
Do they have blocking in them that would prevent air flow from eave to ridge?
Andy.
Residential Drafter/Designer
01-18-2013, 10:05 PM
#9
Vaulted Ceilings
Yes, my ceilings are vented via a ridge vent and eve vents.
GBR, I researched the links you referenced and even though they look 100% correct, the house was built with 2 x 8's and inspected as such. Why in the world and how could the BI require me to put in R-30 or higher which requires a higher rafter after it was all inspected and approved?
Doesn't make much sense to me.
01-18-2013, 11:02 PM
#10
Moderator
Vaulted Ceilings
Me either. Your whole state is under that Energy Code, with no local amendments. My state requires R-49 (Zone 4 marine) as we have our very own Energy Code, so fortunate to go above and beyond the IRC, IBC, and IECC code minimum...surprised they didn't say anything before.
Gary
01-19-2013, 07:57 AM
#11
Vaulted Ceilings
wen was your permit aproved?on your drawings did they call out the r values on the wall and roof sections? my permit was pulled last year prior to them updating the code so i fall under the older values. on my permit drwaings he highlighted te note on wall sections and wrote R13 and such. i had a long conversation with the building inspector on this as mine was stick framed with 2x12 rafters for a cathedral cieling- and how to insulate this properly and to achieve the r factor. under the current code this is impossible and now requires te rafter to be padded out or a scissor truss to be used to achieve this......
great links by the way....
The Following User Says Thank You to gwilkrrs For This Useful Post:
01-21-2013, 10:34 AM
#12
Vaulted Ceilings
Last year, around July-ish. Per my township the homeowner is allowed to produce their own drawings. I was checking them out the other day and there's nothing on there stating anything about insulation, etc. The only thing called out is with regards to needing permits for anything else, i.e. electrical, plumbing, mechanical, etc.
01-21-2013, 08:43 PM
#13
Moderator
Vaulted Ceilings
I'd give the field inspector a call and ask him. Let us know the outcome...
Gary
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
