Vapour Barrier Option In Basement - Insulation - DIY Chatroom Home Improvement Forum
Old 02-13-2014, 08:56 AM   #1
Vapour Barrier option in basement
Just finishing an insulation upgrade in basement prior to adding living space and am wondering about vapour barrier. I always find the joist pockets troublesome to install vapour barrier in and was wondering if it wouldn't be better to vapour barrier the walls up to the top plate of stud wall and then also apply vapour barrier on the ceiling as well? This way would achieve the barrier I want and avoid having to mess with the joist pockets. Is it ok to vapour barrier the ceiling in a basement? This will be finished heated space. Thanks.
slyone is offline   Reply With Quote
Old 02-13-2014, 09:19 AM   #2
Rewards Points: 444
I see no good reason for either for a VB or insulation when used as a living space. My living space basement ceiling is concrete and it hasn't needed a vapor barrier or insulation in 30 years.
Old 02-13-2014, 12:20 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Where is the home?
The Following User Says Thank You to Windows on Wash For This Useful Post:
Gary in WA (02-14-2014)
Old 02-13-2014, 12:28 PM   #4
I am in Nova Scotia.
The Following User Says Thank You to slyone For This Useful Post:
Old 02-13-2014, 10:36 PM   #5
Professional
TotalHomeworx's Avatar
Just staple the VB in the best you can. Acoustic seal could help or tuck tape but isn't necessary. Do not VB between warm zones. VB stops condensation from cold to warm.
www.totalhomeworx.ca
TotalHomeworx is offline   Reply With Quote
Old 02-14-2014, 09:10 AM   #6
Rewards Points: 906
There is a bunch of information out there regarding basement insulation strategies in cold zones.
I would suggest you start there. I don't like plastic vapor barriers as they usually wind up being a bigger issue as compared to a solution.
Old 02-14-2014, 09:25 AM   #7
Vapor barriers are a thing of the past, experience is showing they are not needed and cause more harm than good. They trap vapor instead of prevent it, and can lead to mold.
Huskee is offline   Reply With Quote
Old 02-14-2014, 04:33 PM   #8
Registered User
Rewards Points: 4,924
In very cold locations, a Class 1 VB will work, it is when there is summertime warming that condensation may spike; http://www.buildingscience.com/docum...commendations/
Most of the US shouldn't require poly but in high Zones- 7,8; under the correct applications- it is fine; ftp://ftp.cmhc-schl.gc.ca/chic-ccdh/..._Web_sept5.pdf
No poly-wrapped FG anywhere; http://www.buildingscience.com/docum...Insulation.pdf
Zone 6, poly is risky with moisture problems- Case#3; http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja
Gary
PS. Read last paragraph; http://www.buildingfoundation.umn.ed...oistphenom.htm
Tags
basement , insulation , vapour barrier
Vapor barrier on basement wall gregsenne Insulation 4 10-13-2012 12:27 AM
Vapour Barrier - Full Wrap OR 1 Piece Per Wall Dreams Insulation 3 01-28-2012 12:12 AM
vapor barrier on basement pony wall hobbs in vanvouver Building & Construction 3 02-13-2011 09:07 AM
Densshield and Vapour Barrier rayf01 Building & Construction 6 01-01-2010 01:55 PM
