Vapour Barrier - Full Wrap OR 1 Piece Per Wall - Insulation - DIY Chatroom Home Improvement Forum
Old 01-27-2012, 09:54 PM   #1
Hi Everyone!!
I have a quick question / vote regarding plastic Vapour Barrier...
I am at the stage where i need to hang up my Poly Vapour Barrier over the insulation on my exterior walls. (on the inside of the house / room...it the interior exterior wall)
My questions is as follows:
Which is preferable:
1) Keep the vapour barrier in tack as 1 full sheet by starting at the end of 1 wall then roll it out until the end of the 2nd or 3rd wall all as 1 intact piece
OR
2) Cut the vapour barrier to fit 1 wall at a time and over lap wall 1 onto wall 2 by 2 feet and seal / join them with tuck tape making for 2 or 3 individual sheets of vapour barrier.
I would think number 1 is the proper and correct way and also keeps maximum air flow to a minimum however today I've been told by 3 separate people that method 2 is perfectly safe and good, and just as good and effective as option 1.
Can people please validate this for me and provide some additional feedback / confirmation. I'm looking to see what most people are actually doing and make sure i am not being told incorrect info that could jeopardize or create more problems in the future.
P.S.
I am not sealing with Acoustical Caulking around the edges (as i suck incredibly with Caulking). I will be sealing all sides with Tuck Tape nice and tight to prevent air flow / leakage. Is this going to be a problem?
I appreciate any feedback
Dreams is offline   Reply With Quote
Old 01-27-2012, 10:08 PM   #2
Rewards Points: 14,014
I hope you really meant A product like Tyvec not plastic as you stated.
Old 01-27-2012, 10:13 PM   #3
Sorry, i re-phrased my questions..it's on the inside of the house / room...it the interior exterior wall).
Old 01-27-2012, 11:12 PM   #4
In a little over my head
Rewards Points: 706
Oooh, Ooh. I know this one. I asked a similar question last month. Got an answer, too.
It may not be a concern.
http://www.diychatroom.com/f103/vapor-barrier-question-126978/
Check out GBR's response and the links.
ratherbefishing is offline   Reply With Quote
vapour barrier on ceiling of bathroom? wilsonfrench Building & Construction 20 01-29-2012 08:08 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Vapour barrier and XPS: Continuing Previous Owner's Rennovation interdit_450 Building & Construction 9 05-04-2010 11:59 AM
Roxul without vapour barrier? giannit Building & Construction 8 01-26-2010 04:39 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
