Vapor Barrior Questions
What part of California to start with.
Next, it is very unlikely that you need a vapor retarder level of any sort in this case. While doing the remodel, the best bet would be to air seal all the top plates, penetrations, and other air barrier breaches in the attic floor/ceiling.
Google air sealing and you will find a bunch of results.
Once you let us know where in CA you are, the final answer on the vapor retarder can be given.
The fact that you have very good ventilation and will insulate sufficiently eliminates the necessity for a vapor barrier in large part.
I would prefer to see passive ventilation but that is another discussion altogether.
