Vapor Barrior Or Not ? - Insulation - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 07:36 PM   #1
vapor barrior or not ?
Location is Central Florida . I am redoing a tub surround . 2 of the 3 walls are exterior walls . Concrete Block . I will be putting the surround on Hardi backer board . My question is Do I need a vapor barrior on the concrete block ? .... If so ,, do I need.it to be , Block - Vapor Barrior - styrofoam insulation - Vapor barrior - THEN Hardi backer board ? .... Or can I skip the vapor barrior - insulation - vapor barrior ,,,, and just screw the Hardi backer board to furring strips and then the surround to that ? ... ANY HELP IS APPRECIATED .. THANKS , KZ ....
beeginner is offline   Reply With Quote
Old 05-01-2012, 09:33 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,928
Rigid foam to the outside wall with taped and foamed seams.
No additional vapor barrier required.
Old 05-01-2012, 04:37 PM   #3
Thanks ,, can you explain what you mean a little clearer please ? ....
