Vapor Barrier In A Shed/ Summerhouse - Insulation - DIY Chatroom Home Improvement Forum
Old 06-09-2011, 12:18 PM   #1
I have made a timber shed which i want to insulate should the vapor barrier go on the out side or inside if needed at all and what thickness should i use. Also should i do the roof as well or just walls. Thank you.
2dinners is offline   Reply With Quote
Old 06-10-2011, 09:43 AM   #2
Energy Saver
HomeInsulation's Avatar
Hey 2dinners,
I'm guessing that the shed is an australian slang term for cabin? Because I don't know why you would want to insulate a storage shed
But anyway, in almost all U.S. states, the vapor barrier goes on the interior. You should be looking at it if your standing inside the house. The same goes for the ceilings and floors.
The vapor barrier always faces the conditioned space, i.e. the space you heat or cool.
For most residential insulation, a kraft faced vapor retarder like that on fiberglass insulation is more than enough.
Free How To Insulation Videos @ http://www.howtohomeinsulation.com
HomeInsulation is offline   Reply With Quote
Old 06-10-2011, 10:33 PM   #3
Registered User
Rewards Points: 5,514
Where are you located?
In the South, the vapor barrier always goes on the exterior, pp.6: http://www.buildingscience.com/docum...e-humid-south/
Gary
Old 06-11-2011, 01:39 AM   #4
London
Old 06-11-2011, 10:40 PM   #5
Registered User
I'm not familiar with your climate/code, check with your local building department.
Gary
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Sinking Shed willise Building & Construction 3 05-04-2011 11:34 AM
unsafe wiring to shed? lawsklsux Electrical 7 11-14-2010 12:16 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
