Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 10-16-2011, 09:19 PM   #1
A Little Of Everything
Vapor Barrier Question (Another One)
Sorry for yet another vapor barrier thread. I've done the search & gotten all manner of differing opinions, none of which really address what I'm doing. Anyway...
Tomorrow I'm going to begin studding in & drywalling two walls of a family room/office in a rental house (third wall is already drywalled). I'll be using 2x4 studs & R11 fiberglass bats.
Both walls are concrete block. One wall is an exterior wall, and the other wall is the garage wall.
Conventional wisdom seems to say always put vapor barrier on the "warm side" of the insulation, and I'm tentatively planning to do that, but I'd like to clarify a couple things.
- Would you treat the unheated garage wall the same as an exterior wall, and install the vapor barrier between the studs & drywall?
- Is there any reason to "double install" the vapor barrier, installing a layer against the blocks, then another immediately behind the drywall?
Thanks for your thoughts!
DrHicks is offline   Reply With Quote
Old 10-16-2011, 09:34 PM   #2
Exterior Construction
Windows on Wash's Avatar
No. Do not double vapor barrier.
Where is the home? The necessity of supplemental vapor barrier may be nil depending on the location. If you are in Omaha, painted drywall that is properly sealed is all the vapor barrier you need.
Treat the garage wall as an outside wall.
Old 10-16-2011, 10:46 PM   #3
Thanks - that's what I tentatively planned to do.
And yes, the house is here in Omaha.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
