Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 08-31-2012, 04:11 PM   #1
Vapor barrier question
I live in a 1964 cape. Is home with a raised dormer. We had Panneling removed from the upstairs bedrooms and had new insulation and drywall put in. He put faced insulation and then a poly sheet over that. I know that not ideal and my questions is should it be removed? The exterior is tyvek with foam and vynel. I am worried about mold growing in the walls as we had a mold issue with the fireplace. What would u all do
Mel1978 is offline   Reply With Quote
Old 08-31-2012, 09:13 PM   #2
GBrackins's Avatar
where are you located? vapor barriers/retarders as based upon climate zones, which are based upon physical location ....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-01-2012, 12:17 AM   #3
No permits or inspections? if something was wrong and it was to be inspected, the inspector will not pass it until corrected. Situations like this are a good reason to go through the process.
chrisBC is offline   Reply With Quote
Old 09-01-2012, 08:59 AM   #4
I am in mass. There was a permit but the inspector wasn't here till after the wall was closed. My question is will the double barrier be enough of a problem that I should take down the walls and redo them
Old 09-01-2012, 03:20 PM   #5
GBrackins's Avatar
the wall was closed before an insulation inspection? not typical in Massachusetts. typically you have your framing inspection (after rough plumbing and electrical) and then your insulation inspector prior to hanging wall board or interior finishes. At least along southeast mass.
hear is a link for you to check out. http://www.buildingscience.com/docum...nd-wall-design
Gary
Old 09-01-2012, 09:45 PM   #6
Moderator
How thick is the exterior foamboard? The paper-faced insulation may be alright, but not the plastic.
Gary
Clothes taking longer to dry?
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
