Vapor Barrier Not Used? - Insulation - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 01:24 PM   #1
Question
Vapor barrier not used?
I live in Northwest Ohio. I am remodeling and putting 6 mil vapor barrier behind the drywall on the walls and ceilings. I was trying to find the red tape (semi-transparent) that is specifically used for vapor barrier taping. My local Lowes store did not sell it, Home Depot didn't sell it, and Menard's website said they had it but when I went there, they didn't have it either. The people in the store did not seem to know what I was looking for. They wanted to sell me tape that is used on the exterior for Tyvek House Wrap. Maybe that tape is the same, but I doubt it. So I ended up having to buy the tape on the internet.
Also, Lowes and Home Depot here do not sell the vapor barrier plastic covers that go behind electrical outlets.
This makes me think that no one uses a vapor barrier here, which I think is dumb. I know there is some debate on whether or not they should be used, but this is certainly a cold enough climate that I think it is necessary. The paper vapor retarder that comes on kraft-faced insulation probably helps some, but isn't enough in my opinion.
Has anyone else had trouble finding these vapor barrier products?
bhry is offline   Reply With Quote
Old 07-28-2012, 01:57 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,220
Don't need it where you are. Airtight drywall is more effective.
Old 07-28-2012, 02:07 PM   #3
Drywall will stop the air leaks, but moisture will go right through it. The moisture then condenses inside the wall, on the fiberglass insulation. Insulation doesn't work very well when it's wet and there can also be mold problems.
Old 07-28-2012, 02:15 PM   #4
Air carries more than 50x more water. Vapor retarders are not required for your zone and depending on application can create more issues than they solve.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Canucker (07-28-2012)
Old 07-28-2012, 06:00 PM   #5
Rewards Points: 6,652
Someone has been watching too much Holmes on Homes & Homes Inspections.
Old 07-29-2012, 01:02 AM   #6
Registered User
Rewards Points: 526
You need a vapor retarder, just not a Class 1 for your Zone 5: http://www.buildingscience.com/docum...commendations/
http://www.buildingscience.com/docum...doctypes/diges
Gary
Old 07-29-2012, 11:22 AM   #7
Originally Posted by GBR in WA View Post
Yes. Sorry about that. I always forget to separate out vapor retarders by class.
