The paper facing will stop most of the moisture trying to go to the crawlspace (doing its job well). The poly sheeting will stop all moisture going either way. Ideally, I would replace the poly with foam board for its insulating qualities will keep the wall cavity below the dew point for no condensation (wall cavity is warm). Because the poly has no insulating value, you run a great moisture risk from exfiltration of the bathroom air condensing on the poly wetting the fiberglass losing 60-70% R-value;
http://archive.nrc-cnrc.gc.ca/eng/ib...ling-heat.html
ADA the drywall:
http://www.buildingscience.com/docum...wall-approach/
Paper facing has variable perms, it lets more moisture through the wetter it gets (it would still dry to the inside room), poly is bad:
http://www.buildingscience.com/docum...vapor-barriers
Deep-six the poly with no insulating qualities, and add f.b. The paper facing can be left on
IF the f.b. is thick enough, read page 2 and notice the
varying thicknesses with
varying perm interior vapor retarders, pp. 10-
14 for your Zone 5 location:
http://www.buildingscience.com/docum...nd-wall-design It all hinges on if the cavity is warm enough to prevent condensation due to R-value of the foam for the degree of interior vapor retarder.
Foil-faced (pp.14) is acceptable left exposed in most crawl spaces, check with your local AHJ on fire code requirements to make sure. OR, reuse the poly (over unfaced f.b.) if f.b. is thick enough, still need an ignition barrier on crawl space side.
Gary
Clothes taking longer to dry?
