Vapor Barrier Or Insulating Sheathing In Attic - Insulation - DIY Chatroom Home Improvement Forum
Old 05-11-2014, 11:30 PM   #1
Newbie willing to work
Rewards Points: 30
vapor barrier or insulating sheathing in attic
OK, well after much delay and procrastination, I'm making progress on refinishing the attic in my 60 year old house.
Here are some notes: no soffits/eaves, gable vents on both ends, ridge vent on top, installed baffles from wall plate to ceiling, air sealed with sprayfoam and fireblock, sealed cavities under kneewall, so far, sidestapled fiberglass insulation from attic floor to just above knee wall,
After re-wiring, I was intending to sidestaple insulation from the kneewall to the ceiling, blow in cellulose on attic floor behind kneewall.
Q1) Is there a recommended thickness for the insulating sheathing ??
In the context of "is adding a vapor barrier a good idea?", I read this document:
http://www.buildingscience.com/docum...sealing-guide/
Re: vapor barriers, a lot of threads have gone yes or no with different explanations. But the doc indicates did not mention one. So, I'm moving on to insulating sheathing.
It doesn't explicitly say so but on pages 32/33, the insulating sheathing goes on the part of the knee wall that faces out, correct ?? In the drawings, "outside" is to the left of the wall and "inside" is to the right?? Just want to make sure about the orientation.
Q2) Should I use any kind of vapor barrier or insulating sheathing on the sloped part of the attic wall??
Q3) Off-topic question: I have a PVC plumbing vent that starts behind the kneewall and goes through the roof at a lower height than the attic ceiling. The pipe is about as thick as the rafters, I won't be able to put any insulation between the pipe and the drywall. In the winter, there will probably be a condensation problem. What can I do?? I was thinking of building a soffit to insulate the pipe. But the pipe is roughly midway on a 30 ft long wall. A soffit would look terrible.
Thanks for reading and/or responding!!!
FileOpen is offline   Reply With Quote
Advice insulating a finished attic wall jvetter713 Insulation 2 09-22-2012 11:56 AM
Insulating attic decking BlueBSH Insulation 6 08-09-2012 09:12 AM
finishing insulating attic Roundeye Insulation 12 01-12-2012 10:10 PM
insulating problems in bongalow closet & attic MyEvilBanana Building & Construction 1 01-30-2011 10:01 AM
Insulating a finished attic properly? kokanee123 Roofing/Siding 13 09-18-2009 10:48 PM
