Vapor Barrier In Garage (room Over) Ceiling - Insulation - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 04:16 PM   #1
Vapor barrier in garage (room over) ceiling
I am finishing off my garage that has a future living space above. I live in North Idaho. Which side do I place the vapor barrier?
Tellebelle is offline   Reply With Quote
Old 01-17-2012, 04:21 PM   #2
Rewards Points: 14,312
Always goes toward the conditioned side. (A/C Heat)
Old 01-17-2012, 10:18 PM   #3
Registered User
Rewards Points: 526
In a heating climate, to the inside. In a cooling climate, toward the outside.
Because you are facing a cold garage space with outside air, I would use foil-faced foamboard on the joist bottoms. This will keep the dew point from condensing in the cavity and give an air break if you seal the joints. It also uncouples the joists from the outside temperature; fig. #7: http://www.buildingscience.com/docum...n-crawlspaces/
Cover with 5/8" type X drywall, mud/tape the seams.
Gary
Old 01-17-2012, 10:33 PM   #4
http://insulation.owenscorning.com/u...Insulating.pdf
I've never heard of install it according to it being a heating or cooling area.
Old 01-18-2012, 07:10 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,558
He is referring to the climate zone not HVAC.
Heating climate (i.e. an area of the country where they have more heating degree days) vs. cooling climate.
Old 01-18-2012, 01:25 PM   #6
Registered User
Rewards Points: 526
On the warm side. When I see a picture of a crawlspace with paper facing down, first where they live……it may be correct.
Gary
Old 01-18-2012, 01:40 PM   #7
One solution is to provide a heat duct or two-depending on the size of the garage/living space, directed underneath the future living space.
Then, after the heat ducts are installed below the floor joists of the future living space, frame a 2 x 6 drop-ceiling in the garage below the floor joists of the future living space.
Then, install your 6-mil poly on the bottom of the floor joists of the future living space, being careful to get underneath the ducts, so that the poly is under all ducts, stapled periodically to the floor joists but not too tight- you want the poly to be a little loose so as to allow air flow underneath the joists. Use tuck-tape on all joint seams and the perimeter.
Finally, install your insulation into the drop ceiling. R-28 insulation is the minimum I recommend.
wwsteel7 is offline   Reply With Quote
Garage ceiling joists and beam question Truth Building & Construction 8 01-05-2012 07:52 PM
ventilation help for detached garage music studio project TomSkill HVAC 6 09-09-2010 10:21 AM
Need help in deciding: room above garage CatherineMM Flooring 4 08-15-2010 03:21 PM
Cold room above garage, Asbestos? Crackers Building & Construction 1 09-09-2007 09:35 AM
Drywall Garage Ceiling Recommendations jsjames Building & Construction 6 08-22-2007 03:47 PM
