Vapor Barrier Confusion - Insulation - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 08:56 AM   #1
Rewards Points: 142
vapor barrier confusion
my understanding is that the vapor barrier should be on the warm side of the wall/whatever. around here, that would be the inside. correct ?
ok lets say we have that. but i see it recommended that rigid foam on the exterior should be used. wouldn't this create 2 vapor barriers ? = not a good thing.
Fix'n it is offline   Reply With Quote
Old 05-28-2012, 12:00 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 880
Many exterior foams are not class 1 vapor retarders.
The other benefit of foam on the exterior (if done to sufficient R-Values) is that it raises the temperature of the studs and eliminates the potential of condensation.
Old 05-28-2012, 01:23 AM   #3
Registered User
Rewards Points: 4,914
http://docs.google.com/viewer?a=v&q=...4EyM707m0gPdXQ
Gary
Old 05-28-2012, 09:33 AM   #4
Rewards Points: 142
even if that foam in on the inside of the exterior wall ?
Old 05-28-2012, 02:54 PM   #5
Registered User
Your other post had a better description of the wall make-up, foamboard outside eliminates any vapor retarder inside. pp.16; http://www.buildingscience.com/docum...ting-sheathing
In winter the f.b. inside the wall leaves the sheathing (T&G boards) colder and possibly wet due to exterior leaks, and stops any diffusion (minimal) and air leaks (ADA the drywall) at the inside of cavity, rather on outside the sheathing, on the WRB/f.b. interface. In summer, with moisture drive reversed, the warm outside air would condense on the f.b. in the cavity, rather than outside sheathing; http://www.buildingscience.com/docum...apor-retarders
With the f.b. outside, the R.H. would be controlled by the HVAC, treating the cavity as conditioned-keeping any moisture completely out of the cavity - wetting the framing to rot, pp 3: http://www2.dupont.com/Tyvek_Weather...20Bulletin.pdf
In summer, the f.b. would keep the sheathing cooler (closer to inside temp.) and stop the moisture drive to the inside, if thick enough.
Gary
Old 05-28-2012, 08:24 PM   #6
Rewards Points: 142
so, what your saying is = i shouldn't put the foam board on the inside of the sheathing ?
btw, i am insulating for the winter. summer ac usage is not an issue.
Old 05-29-2012, 12:33 AM   #7
Registered User
Putting the f.b. inside keeps the sheathing colder- last paragraph; http://www.greenbuildingadvisor.com/...s-and-ceilings
Here is the one I was looking for earlier: http://www.buildingscience.com/docum...r-requirements
As WoW said in the first answer, f.b. outside is safer, it's very hard to quality seal the cavity and the exterior against air/moisture; http://www.finehomebuilding.com/how-...de-or-out.aspx
It can be done if carefully detailed, some builders use it; http://www.greenbuildingadvisor.com/...id-foam-option
Gary
Old 05-29-2012, 10:00 PM   #8
Rewards Points: 142
well, i have a lot to chew on.
Estimate confusion fax6202 Plumbing 8 05-14-2012 11:47 PM
Electrical Confusion mholmen Electrical 0 11-13-2011 03:54 PM
Confusion with three way plugs / switches grassy Electrical 2 06-03-2011 03:44 PM
confusion over thinsets for installing Ditra over heated flooring fhknox Flooring 12 01-19-2009 07:21 PM
Chimney Confusion (Long) wehcyar Building & Construction 7 09-03-2008 10:09 AM
