Vapor Barrier In Basement With XPS Rigid Foam? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 09:55 PM   #1
Rewards Points: 83
Vapor Barrier in Basement with XPS Rigid Foam?
Hi there,
I know all the sites say to not use a vapor barrier if using the 2" XPS directly to the foundation walls method, but my building inspector for my town in upstate NY says it will still be required and recommended using paper-backed fiberglass insulation in the 2x4 wall.
I'm certainly not going to win an argument with him, so I am curious, is this really that bad or am I fine doing this? Just wondering if anyone came across the same thing.
Nick
AllGoNoShow is offline   Reply With Quote
Old 02-26-2013, 11:31 PM   #2
Registered User
Rewards Points: 5,204
After some specific research for you, I found; 2010 (which you are not under yet) doesn't require any BELOW grade; http://publicecodes.cyberregs.com/st...0_4_par036.htm
Your 2007 State Energy Code says- #3. Where other approved means to avoid condensation (which is foamboard); http://publicecodes.cyberregs.com/st...7_4_par028.htm
Found it, 402.5 says ABOVE grade walls require vapor retarder/barrier; http://www2.iccsafe.org/states/new_y...y_frameset.htm
Show him/her the other code year print-outs and BSC for possibly letting you skip it, OR have them show you exactly where it says it is required BELOW-GRADE...
http://www.reedconstructiondata.com/...odes/new-york/
Gary
Old 03-02-2013, 02:22 AM   #3
Rewards Points: 1,092
find another inspector who is up to date. surely you are not stuck with just one, are you? hopefully, not, or at least this cat will learn.
Insulating Basement w/ Rigid Foam and Batt Reilley Building & Construction 4 08-03-2013 11:07 PM
Condensation On Foam board in basement tlh123 Building & Construction 1 02-12-2013 02:49 PM
Rigid Foam in Rim Joists MrAngles Insulation 7 09-22-2012 09:11 PM
rigid insulation in basement belindapotter Carpentry 3 01-22-2011 01:01 AM
Rigid foam behind DWV benjamincall Building & Construction 4 08-14-2010 03:27 AM
