Unvented Attic With Fiberglass Insulation - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 09:30 PM   #16
Registered User
Rewards Points: 5,490
Thanks, that helps! You need to decide how to get your locations' minimum R-38 in your roof. R-13 required in walls. The condensation found under the roof sheathing, fig. #2: http://www.buildingscience.com/docum...bout-diffusion
Did you check behind any of the knee wall insulation for wetness to see if you need ventilation? I would add turtle (static) vents on the roof just above the attic floor insulation with baffles and monitor it for wet, if soffit vents are not possible. You are in Zone 4A: http://publicecodes.citation.com/ico..._11_sec002.htm
http://publicecodes.citation.com/ico...001_par001.htm
Gary
Gary in WA is online now   Reply With Quote
Old 12-21-2011, 10:42 PM   #17
AGWhitehouse's Avatar
Originally Posted by hartkem View Post
What would you all do?
If you want to add more insulation to this system, I would look to the outside as opposed to inside. Your upstairs rooms have ceilings that are supported directly by the rafters leaving you will almost no room to improve the dimensional area you have to insulate. So, the cost of removing and replacing all that sheetrock and providing spray foam, furring, the moving, the cleaning, etc. will likely average out to what it would cost you to replace your roof with a nailbase panel system. If venting is something you want, they make those too. A vented panel I recently used had a thickness of 6" with a 1" airspace and an R-value of 28. R-28 + your existing R-19 gives you an R-47... Here's an image of a roof with an insulation board layer and then a nailbase panel top layer: http://www.flickr.com/photos/hunterpanels/5654956569/
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 07:21 AM
Damp Insulation in Attic wiz561 Building & Construction 6 12-23-2010 11:16 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
Blown-in Fiberglass Attic Insulation jdieter Building & Construction 14 11-21-2010 12:39 PM
