Unfinished Tool Room
Is the space conditioned?
If so, insulating the ceiling will only help with noise transmission.
If not, I highly recommend that you properly seal all connection between the two spaces. Plastic will not be an acceptable thermal or ignition barrier not to mention you will be placing the vapor barrier on the cold side of the wall which is also not recommended.
