Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 07-29-2012, 11:11 AM   #1
is unfaced fiberglass bad in basement rim joists?
We recently moved into a 32 year old house. The rim joists in the basement are insulated with unfaced fiberglass bats. It looks sloppy, like scrap pieces were just thrown in. I want to remove the old insulation and put new in. I know that most like to use the foam board and seal/caulk the edges. This would take me forever....especially with the hvac and electrical running thru. I have seen no evidence of moisture problems. Can I just take out the old and add new(and more)? If I fill up the whole cavity, will I have to worry about moisture problems? So far, I have done one area. I used the pink, unfaced R-30. I was able to fit about 3 pieces of it in the cavities. Am I overinsulating....or is it not possible to over do it in this area?
ANDYK. is offline   Reply With Quote
Old 07-29-2012, 12:10 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Unfaced would allow it to breath. If you want to take it a step further, use TigerFoam to seal the bays.
I just used Kraft faced R-13, because I did not want to totally air seal the basement, just wanted to stop cold/hot air convection currents.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 07-29-2012, 12:42 PM   #3
Exterior Construction
Windows on Wash's Avatar
+1
Spray foam it. That will be faster than cutting and stuffing those pieces in.
Old 07-29-2012, 01:33 PM   #4
bbo
i'd second the spray foam. its expensive, but cheaper than my time by far for when I did mine.
bbo is offline   Reply With Quote
Old 07-29-2012, 02:48 PM   #5
Thanks for the replies. I've already started w/ the fiberglass.... Just wondering if multiple layers of r-30 unfaced will cause any moisture issues??? I'm fine with overkill, I just dont want to cause any problems.
Old 07-29-2012, 04:00 PM   #6
gregzoll's Avatar
One layer is all you need. No need for overkill. Update with your location, so that people can better help you. Do suggest going over the info at buildingscience.com, which explains the whole process of making the structure work as a whole.
Old 08-03-2012, 12:53 AM   #7
Moderator
If you are in a heating climate, air seal them from the basement. Fiberglass is air permeable, fine after you install foamboard and canned foam the edges. The idea is to stop infiltrating/exfiltrating air from happening. It does not want to breathe. The rim board expands/contracts with the seasons, letting un/conditioned air right through it. At least use faced toward the warm inside.http://www.buildingscience.com/docum...l_seal_rev.pdf
http://www.buildingscience.com/docum...r-penetrations
Gary
Clothes taking longer to dry?
Fiberglass insulation in basement? nateshirk Insulation 38 11-06-2011 10:44 PM
Strengthening Joists Before Basement Finish braverichard Building & Construction 16 06-20-2010 08:28 PM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 06:43 PM
Exposed fiberglass insulation in partially-finished basement skysurf Building & Construction 1 04-11-2009 10:40 AM
Basement 2x2 furring strips, basement clutter, top plate not attached to floor joists touchsuhas Remodeling 5 12-26-2007 07:01 PM
