Unconditioned Attic Insulation Question - Insulation - DIY Chatroom Home Improvement Forum
Old 01-28-2014, 09:25 PM   #1
I have an uninsulated attic that currently only has Balsam-Wool Blanket insulation (1" silver foil encased blanket with balsam wool material on inside / non-permeable). I have installed the plastic vents to allow air from the vented siffit to enter the attic freely after I add blow-in fiberglass insulation to the proper depth to reach R60 status. My question is: " Can I blow in the new insulation on top of the existing balsam-wool blanket without producing a condensation problem with regards to the "first condensing surface and proper breathing??"
Daveparks is offline   Reply With Quote
Improving attic insulation: remove old fiberglass or just add cellulose/fiberglass? DrSteveBrule Insulation 12 10-21-2013 11:42 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
Attic Insulation tim1218 Insulation 4 09-07-2011 10:18 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
