Triple Wall Stove Pipe - Insulation - DIY Chatroom Home Improvement Forum
Old 09-25-2011, 06:17 AM   #1
TRZ
triple wall stove pipe
I have triple wall stove pipe for a wood stove going thru my attic, Can I safely blow cellulose around that or should there be a clearance between pipe and insulation?
TRZ is offline   Reply With Quote
Old 09-25-2011, 10:02 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,728
Most triple walls flue pipes are not rated for zero clearance on combustibles. You will need to check with local code, however, I would always prefer to see a properly sheet metal barrier around the flue as it comes through the attic floor to seal it with some intumescent caulking and keep the cellulose off of it.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 11:17 AM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Gas pipe to wall heater, can I just put a plug in it? diymonkey Plumbing 6 04-09-2009 06:30 PM
