Too Many Studs Around Windows - Insulation - DIY Chatroom Home Improvement Forum
Old 05-26-2012, 08:10 AM   #1
Rewards Points: 308
Too many studs around windows
Hello everyone,
We are currently building our home in Chicago. Recently we decided to change the size of our window opening and the framers simply added more 2x6 to decrease the size of openings. As such, I see as many as 4 or 5 of these around window to fill the gap (about 10"). Obviously this will affect insulation as we can't put foam or fiberglass batt.
What's the best way to handle this? Remove those studs? Or is loss in R value not that significant?
sbkim is offline   Reply With Quote
Old 05-26-2012, 08:30 AM   #2
Rewards Points: 268
2x6 makes good insulation.
packer_rich is offline   Reply With Quote
Old 05-26-2012, 09:08 AM   #3
Rewards Points: 308
Thanks for the reply I didn't realize that they were good insulators They certainly look sturdy
Old 05-26-2012, 02:30 PM   #4
Just a DIY guy
a 2x6 has an R value of 6.88
http://www.coloradoenergy.org/procor...f/r-values.htm
M3 Pete is offline   Reply With Quote
The Following User Says Thank You to M3 Pete For This Useful Post:
sbkim (05-26-2012)
Old 05-26-2012, 02:36 PM   #5
Experienced
Jackofall1's Avatar
Originally Posted by M3 Pete View Post
Which is not that great at all! Remove the excess and insulate properly.
Mark
Old 05-26-2012, 06:24 PM   #6
Registered User
Rewards Points: 4,894
Seen that link around here somewhere.....
The R-19 compresses to R-17 (inherent with convective loops - more R-value loss), add the whole wall framing thermal loss at 28%..... hope you are installing rigid foam on the exterior and ADA the drywall on the interior.
Gary
Need help on windows Tau44 Windows and Doors 7 02-15-2012 10:31 PM
69 year young lady struggling with windows robaire Windows and Doors 6 01-18-2012 08:01 AM
Pella Windows - Serious Frost Issue snowman72 General DIY Discussions 22 07-08-2011 01:39 AM
replacing windows.. modifying a rough opening by less than 2 inches? diy'er on LI Building & Construction 14 09-18-2010 07:43 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
