Thickness Of XPS Foam - Insulation - DIY Chatroom Home Improvement Forum
Old 10-08-2012, 11:04 AM   #1
Thickness of XPS Foam
I am finishing of part of our basement and am having troubles with the last few details about insulation on the walls.
The basement walls are below grade and when I got my building permit they said the insulation needs to be a minimum of R13.
I had planned on using XPS foam board applied directly to the walls with the seams taped and spray foam used at the top and bottom. Then a small gap and a 2x4 frame that will get filled with R13 insulation batts and greenboard over that.
The question I cannot seem to find an answer to is the thickness of the Rigid foam. The few places I found mention of rigid foam applied like this said to use 1.5", but they did not include the R13 batts as well. Because of space loss and cost, was hoping to go with 3/4" or 1" instead, but did not know if the foam would still serve the purpose of keeping the cold away from the concrete at those thicknesses.
Thanks in advance for any help with my dilemma.
Corey47 is offline   Reply With Quote
Old 10-08-2012, 02:40 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,024
1" is as low as I would go and put the studs (if the wall is plumb) tight to the foam.
Old 10-08-2012, 10:30 PM   #3
Registered User
Rewards Points: 5,244
Where are you located?
That will establish the foam thickness.
Gary
Old 10-09-2012, 12:52 PM   #4
Nebraska
Old 10-10-2012, 01:18 AM   #5
Rewards Points: 1,092
Why go to all the trouble and then weinie out on the foam? Put in 2" and enjoy the place. For batts, try to get Roxul instead of fiberglass. The also make cotton and cellulose; all three are good and no itchy glass shards in your skin and lungs.
The Following 2 Users Say Thank You to jklingel For This Useful Post:
concretemasonry (10-10-2012), Windows on Wash (10-10-2012)
Old 10-10-2012, 10:57 PM   #6
Registered User
2" will work! Or, find the lows of Dec., Jan., and Feb., follow the second 1/2 of this article, enlarge the picture links at the end; http://www.greenbuildingadvisor.com/...ally-necessary
That will tell you the thinnest f.b. with the average R.H. in your basement without condensation wetting the fiberglass or wood framing.
Gary
B-12 Chemtool versus SeaFoam DrHicks Automotive Repairs 16 10-01-2012 09:57 PM
R-Value Thickness foam board in basement floors/walls alecmcmahon Insulation 6 01-10-2012 03:38 PM
Minimum foam board thickness over OSB Arky217 Building & Construction 3 01-11-2011 11:13 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Exterior Foam sheathing thickness? teachtech Building & Construction 4 11-29-2008 05:36 AM
