Thick Pipe Insulation Worth It? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Windows on Wash
Old 01-06-2017, 10:08 AM   #1
Rewards Points: 32
Question
Thick pipe insulation worth it?
I see that Armacell makes a 2" thick Armaflex pipe insulation with an R-value of 16. But I've also heard that the higher the R value, the less return on investment you're going to get.
If I already have an R-3 foam insulation on my water heater's hot water pipe, would it be worth it to upgrade to R-10 or even R-16, at least in the first 6 feet of pipe?
brian0918 is offline   Reply With Quote
Old 01-06-2017, 12:19 PM   #2
Rewards Points: 13,732
Re: Thick pipe insulation worth it?
Not going to do a thing.
Old 01-06-2017, 01:37 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,676
+1
Inside a conditioned space, its mostly a waste of money once it is even slightly insulated.
SeniorSitizen likes this.
Old 01-07-2017, 07:25 AM   #4
hkstroud's Avatar
Rewards Points: 1,916
Insulating an interior water pipe will reduce the noise of water movement. Won't do much of any thing for energy savings.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Torn insulation in attic/knee wall Marky82 Insulation 15 09-06-2016 09:23 PM
Is this the right drainage pipe maddog1 General DIY Discussions 19 05-08-2014 08:46 AM
Pricing a 1 layer tear off of a flat roof. Then installing 1-1/2 thick insulation and 60m. thick EPDM. I need a price per square on labor and materials. Thank you. Tim. pete1700 Roofing/Siding 11 07-19-2011 08:31 AM
High Heat pipe insulation? secutanudu Plumbing 1 02-05-2011 09:31 PM
Pipe Insulation: Foam or Rubber? EE playing with HVAC HVAC 2 11-01-2008 01:35 AM
