Thermal And Sound Insulation For Bedrooms Over Garage - Insulation - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 09:58 PM   #1
Thermal and Sound Insulation for Bedrooms over garage
Hi everyone, I am in the process of buying a house (20+ years old) so I think I should get this planned out early. Right now all three bedrooms are located above the garage. One obvious concern is thermal insulation. I did some research on the Internet, according to "dr. energy saver", they can remove the siding, drill some holes and spray cellulose inside to fill all the existing gaps. I am sure there are other ways to improve the thermal insulation, please share with me any other good ways.
Another concern is noise coming from the garage. I am worried about the noise from starting the car in the morning as well as opening/closing garage door because my wife is a very light sleeper. What would be some of the good ways to greatly reduce those noise? I am thinking along the line of putting extra materials on the ceiling of the garage such as Quietrock or two layers of drywall w/ green glue. By the way, the garage door is opened by hand (not opener), how should the noise of opening/closing door be reduced? Would the extra materials on the ceiling take care that as well?
Thanks a bunch!
sunlight33 is offline   Reply With Quote
Old 04-15-2013, 12:20 AM   #2
Registered User
Rewards Points: 5,256
As far as the insulation, fig.7 and cover with required fire type X drywall; http://www.buildingscience.com/docum...n-crawlspaces/
Gary
Soundproofing/deadening wwkayaker Building & Construction 20 06-07-2013 11:54 AM
Can you use "safe and sound" as thermal insulation zantar Building & Construction 3 02-21-2010 10:16 PM
