Thermal Break Walls ? - Insulation - DIY Chatroom Home Improvement Forum
Old 03-14-2012, 10:52 PM   #1
Rewards Points: 142
thermal break walls ?
hello. my new to me house is old/er, 1920's ? it has bad windows and electric . i will be addressing these issues also. the inside walls are plaster/lathe. the attic has minimal and old bat insulation (i plan to blow over this with ?). i was told that it is very possible that i have no insulation in the walls. i am thinking that if i do, it is minimal like the attic.
anyway. i am thinking about taking the plaster/lathe down on the exterier walls.
updating electrical and windows. now, the insulation, i am thinking thermal breaking the walls. framing isn't an issue, nor is wall thickness(i'm thinking).
what i want is "bang for buck" insulation = lower gas bills.
i am DIYing this. and from the videos i have seen, taking the P&L down doesn't look too hard, only messy. but if there is a good alternative, i will consider it.
thanx for your expertise
Fix'n it is offline   Reply With Quote
Old 03-14-2012, 11:28 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 894
Do you intend to do a complete thermal break of the walls or do you just want to insulate and air seal them?
What is the exterior of the home? You must pay special attention to the exterior and how it has breathed and lived to this point. Changing that dynamic can have disastrous consequences in some cases.
Thermally breaking the wall would involve some sort of staggered wall design or a rigid foam. Just properly insulating and air sealing the walls would be a considerable upgrade over the existing construction. Combine that with proper windows, attic air sealing and insulation, and you house will be 1000X better than before.
Old 03-15-2012, 12:35 PM   #3
Rewards Points: 1,092
+1 for Windows. Maybe look at the simpler, big benefit options. As for "blow over this w/ ...." I'd use cellulose. It will sort of crust over and minimize wind washing. It is also fairly cheap, easily diy, and keeps bug/rodents out pretty well, assuming it is treated w/ borates. Just make sure you leave ventilation at the eaves.
Old 03-16-2012, 08:19 AM   #4
Rewards Points: 142
i was thinking that a complete staggered stud would be the best. but if all that extra work and expense will only get me a small increase over another method , i will look at the other methods.
see pic. it seems to be some kind of asphalt shingle. idk yet what is under it.
i would love to replace or cover it with new siding. but with the economy/my job, its looking like that will be a ways off, if ever.
1000x better would be great . but i have to keep it in budget.
Old 03-16-2012, 08:42 AM   #5
Rewards Points: 142
thanx. here is a pic of the attic . i am about 15' from the back behind me.
and iirc those are 2x4 joist . there are vents on the (5y/o ?) roof, but no soffit vents that i can find. i am thinking that that window in the pic is made to leak air.
Old 03-16-2012, 01:50 PM   #6
This is easy. Blow cellulose over the whole attic as thick as is appropriate for your area (code + several inches). While you are ripping the inside up, be sure to think about air sealing the interior; all penetrations, wall plates, etc. As for double-studding the walls, if you can afford it, sure; even having the two walls separated by 2" would help immensely. Dense pack with cellulose or Spider fiberglass. If you leave the walls single and are re-siding, then you can get a good thermal break by installing exterior rigid foam. Greenbuildingadvisor.com has a good blog titled "How much exterior foam?" or something like that. Search there and you'll find what is recommended for your area vs how much insulation you have inside. Between the studs, if single wall, use Roxul mineral wool. New windows may or may not pay for themselves, but would likely improve comfort. They are spending, so maybe leave them for later.
Old 03-16-2012, 11:58 PM   #7
Registered User
Rewards Points: 4,924
Is that a paper/foil facing on the attic floor insulation?
Here is the one I use a lot, even has "best bang for the buck" comparison as well as moisture potential and thermal values: http://www.buildingscience.com/docum...ermal-analysis
Notice the rim joist areas in that article.... http://www.buildingscience.com/docum...l_seal_rev.pdf
Start by air sealing the basement to help stop the stack effect in your balloon framed walls: http://www.wag-aic.org/1999/WAG_99_baker.pdf
Gary
Old 03-17-2012, 10:08 AM   #8
Rewards Points: 142
ok, cellulose it is. anyone estimate the cost for a 30'x36'x12" ? i will get the stuff from HD as they are the closest.
air sealing = of course.
the cost for double studding. for a 24'x9' wall. that should be about $100 for the lumber ? i was planning to space it out 1". thoughts on this ?
seems to me that the insulation is going to be the most costly item. unless i can use something else if i do the double studs.
this place HAS to have new windows. the current ones are BAD.
Old 03-17-2012, 10:14 AM   #9
Rewards Points: 142
Gary
yes, but idk which it is. i would go up there, but i have yet to bring my ladder here
thanx for the links. i just looked. the basement has bricks/mortar in front of the rim joist . though i am sure they are leaking a little.
Old 03-19-2012, 12:46 AM   #10
Registered User
With the brick at winter temp. and the solid wood rim R-value at R-1.25 per inch.....
Gary
Old 03-19-2012, 09:48 PM   #11
Rewards Points: 142
do you think it would be a good idea to remove the brick and put in something else ? i have a small demolition hammer that should make short work of it.
right now i am looking for new windows for the basement. as they are pretty bad.
also, i am going to get a wood burning stove for down there. the basement is going to be a man cave, butt kickin home theater, pool table, shuffle board, etc.
so i could burn a fire for heat while hangin down there., to help save the gas bill.
this weekend i am going to get my ladder and go up in the attic to see what i am working with.
Old 05-20-2012, 10:24 AM   #12
Rewards Points: 142
when you say separated by 2". do you mean having the wall 2" thicker, or building another wall, separated by 2" ?
in this pic, the stud does not go to the bottom plate, because of the lower 2x4. i could do it like this. but i am thinking to just get 2x2's.
i am still not decided if i should do this. even though it seems to make a LOT of sense.
Old 05-20-2012, 10:31 AM   #13
Rewards Points: 142
oh. the original studs are 3 1/2" (when did they start going from "real" dimensional lumber, to downsized lumber ?).
and adding a 2x4 like this, will add 1 1/2", for a total of 5" for insulation. that is about a 45% increase.
Old 05-20-2012, 02:50 PM   #14
Rewards Points: 150
If building a staggered wall, fir out 2" for a 5.5" wall (today's 2x6). This will correspond with insulation thicknesses. Also, remember that a staggered wall presents its own difficulties (as I learned by recent experience), one of which is insulating.
I am assuming that you want to build a true 'staggered stud' wall and not just increase the wall depth by firring onto existing studs. A true staggered wall will provide a thermal break, as the inside wall is mechanically "decoupled" from the outside wall (sans minimal connecting points, i.e., at bottom and top plates):
http://www.soundproofingcompany.com/...-construction/
As you can see from the above link, in addition to a thermal break, a staggered wall also helps to soundproof the space.
As to the insulation issue,the staggered wall will offset the cavities so that one 5.5" bat will not simply fit. Also, it was more work to properly insulate. Here is a link to a post describing those insulating issues and how I solved them by 'splitting' the bat. I used R-23 (5.5") Roxul stonewool:
Cutting Roxul
That said, foam would be a good, albeit more expensive way to insulate a staggered wall. Certainly less labor intensive.
Also, while you are airsealing in the open walls, don't forget to airseal the outlets. You could just caulk the wire entry points, but putty pads seal the enire box and do a great job against sound and air.
rightit is offline   Reply With Quote
The Following User Says Thank You to rightit For This Useful Post:
Fix'n it (05-20-2012)
Old 05-20-2012, 08:30 PM   #15
Rewards Points: 142
yeah, i would stagger. but i would put the new stud right next to the old one.
not a perfect idea, but would work for me.
thanx for the 2" tip.
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 01:07 PM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 03:43 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
Thermal Break For Tile fierysun Flooring 2 03-06-2008 07:22 PM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 03:50 PM
