Is There Asbestos In Old Mobile - Insulation - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 12:22 PM   #1
Is there asbestos in old mobile
I have a 1960 Kit mobile home, in bad shape, I would like to know if it would have asbestos in it and if so where/ Did they use any asbestos insulation in walls, ceiling and what about floors? Would appreciate any info on the above. Thanks, Kirby.
rkirby9905@msn.com
mona may is offline   Reply With Quote
Old 05-15-2011, 08:02 PM   #2
Rewards Points: 27
There is a fairly strong chance it has some in it. Place where I can think of is if it has/had a old tile floor the tiles or the adhesive were made of asbestos. They are fairly easy to spot IE black tar like adhesive and the tiles are typically 9x9. As long as it's sound and not friable IE broken up and possibly airborne it's not really an issue. Most old homes have it. In that case as long as the subfloor is in AOK shape you just throw 1/4" plywood on top, staple it down, and lay your new floor. Here is some info. http://inspectapedia.com/sickhouse/asbestoslookB.htm. As far as anything else I'm not sure and somebody else will chime in if there is something I'm unaware of.
kossuth is offline   Reply With Quote
Old 05-15-2011, 10:13 PM   #3
Too Short? Cut it Again!
I honestly do not know but kit homes would have been a perfect application for use of asbestos. Best to pull some samples and have them tested if you are concerned. The real danger with asbestos is when its fibers go airborne so leave as much alone as you can.
Old 05-16-2011, 07:11 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Asbestos was used practically everywhere at some time or another. The only way to be certain is to have samples of suspect materials tested. Insulation, flooring material (both tiles and sheet), acoustical ceilings, wallboard, exterior siding and roofing materials all could have it. Some places it's a problem, other places, not so much.
ASBESTOS..... lots of questions. Dyoung Building & Construction 22 02-14-2012 05:15 PM
Power loss carlko Electrical 55 03-12-2011 05:26 PM
Asbestos in old vinyl floor taubel Flooring 3 08-19-2010 08:48 PM
Botched Asbestos Removal Several Years Ago...Remediation? vs1988 General DIY Discussions 10 08-16-2010 11:28 PM
asbestos & paint--let's talk. jaes Painting 4 08-10-2008 10:49 AM
