Testing Insulation ? - Insulation - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 08:55 PM   #1
Rewards Points: 240
testing insulation ?
since blowing cellulose in my attic. i am wondering just how effective it is.
i am thinking that i could put a piece of paper on the cellulose, pressing it down slightly. then check the temp on the ceiling. then check the temp on that piece of paper. and the temp in the attic.
example :
ceiling 72*
piece of paper 35*
attic temp 30*
not bad, but need more cellulose.
am i loosing it
Fix'n it is offline   Reply With Quote
Old 11-04-2012, 10:09 PM   #2
Rewards Points: 14,312
Your way over thinking this.
http://www.energystar.gov/index.cfm?...sulation_table
And you test would be useless.
Did you air seal before the insulation?
Both in the attic and under the house?
gregzoll (11-05-2012)
Old 11-04-2012, 10:30 PM   #3
Rewards Points: 240
yeah, perhaps. i think i am going to try it anyway.
how is that ?
sure, in that area.
the basement. thats a different story, but i'm working on it.
Old 11-05-2012, 05:11 AM   #4
Or you could check your energy bill.
Hydro One..here in Ontario has a website where you can track your usage by the month, day and even hour. After I had some blown in installed, the difference was immediate and dramatic.
creeper is offline   Reply With Quote
Old 11-05-2012, 08:41 PM   #5
Rewards Points: 240
my bill isn't high. but we are just getting cold here. this months bill will tell a lot.
i will see what my ideal yields and report back.
Old 11-06-2012, 08:17 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,564
Originally Posted by Fix'n it View Post
am i loosing it
Yes...actually it may already be gone.
You are a DIYing nut.
Old 11-06-2012, 08:42 PM   #7
Rewards Points: 240
yeah. and they said EDISON was a nut.
Old 11-06-2012, 08:45 PM   #8
Most geniuses are fringe.
FYI...I was paying you a compliment.
Old 11-06-2012, 09:59 PM   #9
Registered User
Rewards Points: 526
Food for thought: http://www.greenbuildingadvisor.com/...cience-podcast
How much is enough for the returns; http://www.enersavesystems.com/pdf/E...Insulation.pdf
Gary
Old 11-06-2012, 11:56 PM   #10
I would agree that 10" of a well installed insulation is pretty ideal.
The reality is that cellulose will compress overtime and while its R-Value will slightly increase, the net installed height will go down.
Take into account also that most installers do not get a perfect and uniform thickness. Shooting for a slightly higher number ensures that you have that minimum amount required.
Old 11-07-2012, 09:53 PM   #11
Rewards Points: 240
i agree. idk if it is even possible to get a near perfectly flat layer. i know mine is not. i plan to add some more one day.
Cold hard facts Nailbags Insulation 14 05-26-2012 04:15 PM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
