Taping Multiple Layers Of Foam Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 07-04-2014, 06:06 AM   #1
Rewards Points: 79
Taping multiple layers of foam insulation
I am finishing my basement. I already had 1" insulation over concrete when I purchased the house. I built my non load bearing exterior walls with 2x2 plates top and bottom and using 2x4's turned sideways creating 1.5" thick walls.
I got some Owens Corning insulation which states it is 7.5 r value. Not sure if that is total or per inch. If it total that I need to return it for a higher to meet code here.
However I was wondering about taping. Currently the 1" is not taped. I was wandering if both 1" and 1.5" should be taped. Or just 1 layer? My concern is with moisture. Anyone have an answer to that? Or my question about the r-value of that insulation?
jbean8510 is offline   Reply With Quote
Old 07-04-2014, 08:32 AM   #2
Rewards Points: 94
In general, the r value stamped on the product is the total r value, no need to do any cyphering to figure it out. SOUNDS like XPS foam which has the lowest r value per inch of the commonly used foam sheets. Ron
ront02769 is offline   Reply With Quote
Old 07-05-2014, 01:21 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 854
XPS is not the lowest. EPS is lower and ISO is higher.
The OC Foamular is typically an XPS product.
Old 07-06-2014, 02:48 AM   #4
Rewards Points: 79
Yeah I'll be returning the Owens Corning xps for some ISO.
Now what about the tape? Should I tape the 1" foam against concrete? The ISO layer on top? Neither? Both?
Old 07-06-2014, 10:03 PM   #5
Rewards Points: 79
If I don't tape anything it seems like it would be drafty. But taping worries me about moisture
Old 07-07-2014, 11:14 AM   #6
Rewards Points: 95
Condensation - is produced in the home by people.
Condensation is the result of water vapor produced by people in the home.
People cooking, washing, drying, breathing, sweating...and animals.
Water vapor is programmed by nature to move to cold surfaces (surfaces below dew point) to turn into condensation.
If your insulation is thick enough to hold the room side surface above dew point then any tape you fit on it will keep dry.
Just make sure that all holes, gaps and cracks are tight, that is to say water vapor proof. The best thing to do, is to cover the whole wall surface with plastic sheet, if you don't then water vapor will find its way through the insulation cracks and will condense on the cold wall behind it.
Perry525 is offline   Reply With Quote
Old 07-10-2014, 08:53 AM   #7
Rewards Points: 79
Soooo seal up everything completely?
Old 07-10-2014, 09:25 AM   #8
Rewards Points: 95
Avoid Condensation
Its simple really, by presenting a warm surface to water vapor (that is to say one above dew point) the water vapor is held in the air (or goes somewhere else to condense usually the cold surface of a window) by covering the insulation with a plastic sheet, this removes all the problems caused by cracks in the insulation.
Look at it this way.....things can be made air tight reasonably easily, but the molecules of water vapor are so small that they can live and exist between the molecules of air.
Make sure you glue/seal any gaps between plastic sheets and round the edges of plastic sheets.
The Following User Says Thank You to Perry525 For This Useful Post:
Windows on Wash (07-10-2014)
Old 07-10-2014, 09:32 AM   #9
Rewards Points: 854
Perry is all over it.
The benefit to staggering the seams and offsetting them is to get more air barrier layers and more foolproof sealing.
Spray foam insulation troyce1 Insulation 12 12-14-2014 07:30 AM
Vapor sealing with open cell foam insulation PerpetuallyRepairing Insulation 6 12-17-2011 10:16 PM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 10:03 AM
Pipe Insulation: Foam or Rubber? EE playing with HVAC HVAC 2 11-01-2008 02:35 AM
Air cavity required behind spray foam roof insulation BigJimmy Building & Construction 9 06-08-2008 01:45 PM
