Does this even exist?
I'm looking to redo my basement bathroom over and its not the biggest room, so any space saved is great. I have a wall about 6ft wide and is also the foundation, so its cement. The previous owner covered it with a thin board of sorts, then wallpapered and painted. I'm looking to remove it, and over the past year or so, that room is pretty cold and the wall is cold to the touch.
Can you suggest what I can put there in terms of insulation, while not taking much space? Meaning, adding an additional 4 or so inches to the wall will def cramp the toilet space.
The wall seems dry and there's no indication of any moisture/water. Its also in the same room as the washer and dryer.
I removed a piece of the wallpaper, which ended up being a larger chunk...so.. there's no going back now.
Thanks!
Thanks!
