Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 01-05-2013, 03:49 PM   #1
Styrofoam Insulation Question
Is it a good pratice to install Styrofoam Insulation sheets over the wood sheathing (to form a thermal break) and then put fiberglass insulation on the inside between the 2 x 6 studs?
rmaheux is offline   Reply With Quote
Old 01-05-2013, 05:22 PM   #2
No because you would be installing a vaper barrier on the wrong side of the wall.
The vaper barrier needs to be on the inside.
Old 01-05-2013, 05:47 PM   #3
Moderator
Yes, it's the best way, short version: http://www.buildingscience.com/docum...r-requirements
Long version; http://www.buildingscience.com/docum...ting-sheathing
Depends on the sheathing (OSB or PLY) and the siding type. Most important= where are you located?
Gary
PS. Welcome to the forums!
Clothes taking longer to dry?
Old 01-05-2013, 05:51 PM   #4
Pleas go back and add your location to your profile for ansewers not questions.
Just go to the top left and tap on your name where it says welcome to make the change.
Old 01-05-2013, 08:25 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
in a cold location its perfectly fine depending on the type of foam your using as open cell foam has to have house wrap installed over it. .closed cell foam can just be put on hte wall by itself but be sure to use shiplap foam and tape the vertical seams horizontal seams are left open so it can still breathe
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
rmaheux (01-06-2013)
Old 01-05-2013, 08:41 PM   #6
Roofmaster
As long as the poster knows Blue Styrofoam (EXPS) by Dow Chemical from bead board (EPS) The White Cheap Stuff.
Styrofoam is Blue, and is a Registered Trademark of Dow Chemical Co. It is a closed cell extruded polystyrene insulation. It is so resistant to water that it is used in inverted configuration in low slope roof systems where it is placed on top of the roof membrane. (Protected Membrane Roof System).
And Yes, we need to know where you are to know where the Vapor Barrier/ Retarder should go, but Generally Speaking you want the dew point to fall in about the middle of the insulation package.
" A lot of men build things, and a lot of things fall down "
Old 01-06-2013, 09:20 PM   #7
Thanks for your reply regarding the styrofoam insulation over the OBS, I am having a new home built in Nova Scotia (framing in-process) and was wondering if it may prevent the vapor from excaping.
Old 01-09-2013, 12:21 AM   #8
Moderator
Exterior foamboard is fine anywhere, warm or cold location. It should be thick enough to keep the backside of the sheathing warm so moisture doesn't condense there or on the cavity insulation (dew point= first condensing surface); http://www.buildingscience.com/docum...nsulation/view
http://www.buildingscience.com/docum...bout-diffusion
The open-cell foam (EPS- more than one type) is fine for side-wall applications (hard to get the R-value/window detail with thickness for your location), even below grade; http://archive.nrc-cnrc.gc.ca/eng/ib.../ctus-n36.html
The best place for the WRB (housewrap) is between the foam/structural sheathing, whether cc or oc; http://www2.dupont.com/Tyvek_Weather...h_Bulletin.pdf
http://www.buildingscience.com/docum...a-foam-shrinks
Describe the wall make-up.
Gary
Another Rigid Insulation over Block Question jdon88 Building & Construction 1 02-16-2011 11:25 PM
yet one more insulation question Mike in Arkansas General Discussion 6 11-11-2010 10:47 PM
Insulation question veesubotee HVAC 8 10-11-2009 09:48 PM
Garage insulation question trojanman1 Building & Construction 7 09-16-2009 03:51 PM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 09:19 AM
