Stud Wall Cavity - Insulation - DIY Chatroom Home Improvement Forum
Old 06-12-2012, 09:55 PM   #1
Rewards Points: 264
stud wall cavity
I have a question about insulating a stud cavity. Typical 2 x 6 wall(or 2 x 4) cavity with studs 24" OC.
If I spray foam(using great stuff or similar) the vertical and horizontal seams where the stud meets the exterior sheeting then install a piece of blue foam by pressing it into the wet spray foam will I get a good seal? I think this would be less expensive than spray foam but haven't actually compared the costs yet. Is this a reasonable way to insulate? This would be for a stand alone building, maybe 24' x 16', used a studio or office space. Climate is zone 2, hot and humid.
Comments are appreciated, thanks.
7echo is offline   Reply With Quote
Old 06-13-2012, 10:34 PM   #2
Registered User
Rewards Points: 4,894
In your location that would work. I would caulk the plate/stud/sheathing joints and canned foam the f.b around the edges, cutting it 3/8 smaller than cavity. No gap to drywall, not tight to OSB. http://www.buildingscience.com/docum...+Humid+Climate
Check for termites and radon; http://termites101.org/termite-basic...ites-by-region
http://energy.cr.usgs.gov/radon/rnus.html
Gary
P.S. ADA the drywall: http://www.buildingscience.com/docum...wall-approach/
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
interior wall frame has an angled piece at bottom of one stud. Why! waitingtohear Building & Construction 14 05-03-2012 09:50 PM
1-2x6 Stud Cut Through on load bearing wall. 2 top plates still in tact. raguy55 Building & Construction 1 03-22-2012 11:45 PM
Question regarding adding a stud wall to a brick structure jcieutat Building & Construction 0 12-15-2009 08:41 PM
Interior Wall Stud Joist Connection Issues. Brandnewruins Carpentry 5 04-23-2009 12:46 AM
